Could not find core in Coresight setup
    • Could not find core in Coresight setup
      Dear
      We are having programs with J-Link. Please Help me
      02-00000000-00-00002390-009A: ***** Error: Could not find core in Coresight setupInitTarget()Protection bytes in flash at addr. 0x400 - 0x40F indicate that readout protection is set.
      02-00000000-00-00002390-0039: For debugger connection the device needs to be unsecured.
      02-00000000-00-00002390-0058: Note: Unsecuring will trigger a mass erase of the internal flash. (2238ms, 2388ms total)
      02-00000000-00-00004336-01F9: T1D50 000:190 Executing default behavior previously saved in the registry.Device will be unsecured now. >0x10B TIF>Found SW-DP with ID 0x2BA01477 >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF>Scanning AP map to find all available APs >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF>
      02-00000000-00-00004344-01FA: >0x21 TIF>AP[2]: Stopped AP scan as end of AP map has been reachedAP[0]: AHB-AP (IDR: 0x24770011)AP[1]: JTAG-AP (IDR: 0x001C0000)Iterating through AP map to find AHB-AP to use >0x42 TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x42 TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x30 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x30 TIF> >0x0D TIF> >0x21 TIF>
      02-00000000-00-00004445-00A7: >0x0D TIF> >0x28 TIF>AP[0]: Skipped. Invalid implementer code read from CPUIDVal[31:24] = 0x00AP[1]: Skipped. Not an AHB-AP returns 0xFFFFFEFB (4293ms, 4443ms total)
      03-00000000-00-00004445-002E: ERROR: Could not find core in Coresight setup
      03-00000000-00-00004445-0024: ERROR: Could not connect to target.
      Could you try the following and send a screenshot of your J-Link Commander connect sequence?
      The device seems to be in readout protection state.
      To unlock the device the reset pin must be connected, otherwise the unlock will fail.
      More information can be found here: wiki.segger.com/S32K14x_series
      It is also possible to lock the device permanently, if this is the case here then the target device can't be recovered anymore.
      In your last picture you are using the STR9 commander. Before you tried to connect to the NXP S32K14 series.
      Which one is it?
