DROPDOWN widget select BUG
    • DROPDOWN widget select BUG
      When I using DROPDOWN_SetItemDisabled disable some items of the DROPDOWN widget , UP and DOWM key still CAN select disabled items if it focused.
      When the DROPDOWN widget in expand mode, Disabled items cannot be selected.
      Chensie
      Thanks for pointing this one out.
      We will fix this behavior. In the meanwhile you can use the workaround below. You have to set a custom callback for the DRAOPDOWN widget and react on WM_KEY. If the selection is disabled set a new selection.
      Set the callback below with WM_SetCallback(hDropdown, _cbDropdown);
      2. *
      3. * _cbDropdown
      4. */
      5. static void _cbDropdown(WM_MESSAGE * pMsg) {
      6. WM_KEY_INFO * pInfo;
      7. static int OldSel;
      8. int NewSel;
      9. int NumIndexes;
      10. switch (pMsg->MsgId) {
      11. case WM_KEY:
      12. pInfo = (WM_KEY_INFO *)pMsg->Data.p;
      13. if (pInfo) {
      14. if (pInfo->PressedCnt) {
      15. OldSel = DROPDOWN_GetSel(pMsg->hWin);
      16. DROPDOWN_Callback(pMsg);
      17. NewSel = DROPDOWN_GetSel(pMsg->hWin);
      18. NumIndexes = DROPDOWN_GetNumItems(pMsg->hWin) - 1;
      19. while (DROPDOWN_GetItemDisabled(pMsg->hWin, NewSel)) {
      20. if (NewSel < OldSel) {
      21. NewSel = (NewSel > 0) ? NewSel - 1 : OldSel;
      22. } else if (NewSel > OldSel) {
      23. NewSel = (NewSel < NumIndexes) ? NewSel + 1 : OldSel;
      24. }
      25. }
      26. DROPDOWN_SetSel(pMsg->hWin, NewSel);
      27. }
      28. }
      29. break;
      30. default:
      31. DROPDOWN_Callback(pMsg);
      32. break;
      33. }
      34. }
