[SOLVED] Ozone and fopen, how does it work ?
  • [SOLVED] Ozone and fopen, how does it work ?
    Normally when using fopen(), I only need to specify the file name and the file gets created in the project directory (It works with IAR and Eclipse).
    But with ozone, there is a problem. For example :
    1. fopen ("Image.bmp", "w"); // This function return Null and no file is created
    So, I tired this:
    1. fopen ("\\Image.bmp", "w");
    Now it works fine but the file get created in the C drive not in the project directory.
    Is there a way to specify where the files created by Semi-hosting should be saved in Ozone ? And is It possible to save them in the project directory ?
    I looked at the reference manual and i couldn't figure out how to do it. Could you help me ?
    Thanks.
    Ozone does not implement fopen for semihosting as Ozone is a host PC application and does not execute code on the target device.
    You can use fopen in your C source code however that runs on the target device which then will open the file on your host PC as expected.
    More information can be found in the J-Link user manual UM08001 and in this thread: [SOLVED] Semihosting and JLink 6.32a
