Draw bitmap with GUI_BMP_DrawEx() function, LPCXpresso54608 board
    • Draw bitmap with GUI_BMP_DrawEx() function, LPCXpresso54608 board
      I can´t draw bitmap with GUI_BMP_DrawEx() function, this is my code:
      static void _ShowBMP(const TCHAR* sFilename)
      int XSize, YSize, XPos, YPos, result;
      FIL hFile;
      FRESULT error;
      error = f_open(&hFile, sFilename, (FA_READ | FA_OPEN_EXISTING));
      if (error == FR_OK)
      GUI_ClearRect(0, 0, 480, 272);
      XSize = GUI_BMP_GetXSizeEx(_GetData, (void *)&hFile);
      YSize = GUI_BMP_GetYSizeEx(_GetData, (void *)&hFile);
      XPos = (XSize > 480) ? 0 : 160 - (XSize / 2);
      YPos = (YSize > 272) ? 60 : 150 - (YSize / 2);
      result = GUI_BMP_DrawEx(_GetData, (void *)&hFile, XPos , YPos );
      if (!result)
      GUI_Delay(2000);
      f_close(&hFile);
      and my getData() function
      /*static*/ int _GetData(void * p, const U8 ** ppData, unsigned NumBytesReq, U32 Off)
      U8 _acBuffer[0x20000];
      unsigned int NumBytesRead;
      FIL* phFile;
      FRESULT error;
      phFile = p;
      // if (NumBytesReq > sizeof(_acBuffer))
      // NumBytesReq = sizeof(_acBuffer);
      // Set file pointer to the offset location
      error = f_lseek(phFile, Off);
      error = f_read(phFile, _acBuffer, sizeof(_acBuffer), &NumBytesRead);
      *ppData = _acBuffer;
      return NumBytesRead;
      I have try increasing
      GUI_ALLOC_AssignMemory((void *)GUI_MEMORY_ADDR, GUI_NUMBYTES); This to 0x200000
      and I have try increasing _acBuffer
      and I have try with (void *)&hFile insted of &hFile as someone mentioned in other post, but nothing happend
      GUI_BMP_DrawEx() function returns 1 so, something is wrong.
      could anybody help me?
      Which version of emWin are you using?
      What kind of BMP are you trying to display?
      Does it work with another BMP (e.g. instead 16bit a 24bit BMP)?
      On my end the BMPs are getting displayed correctly.
      You can find the emWin version in GUI_Version.h.
      Can you also post your LCD configuration (I guess it's named support_emwin.c)?
      I gave it a try and checked it with version 5.38 of emWin. The BMPs are getting dipslayed properly.
      Maybe there is an issue with the filesystem?
      Please try the example attached. There I draw the screen.bmp slightly different. I converted into a c-array and compile into the application. This way you don't have a FS in between.
      • DrawBMP.zip
        (339.4 kB, downloaded 300 times, last: )
