[SOLVED] Flash SPI memory through JTAG
  • [SOLVED] Flash SPI memory through JTAG
    Dear Segger Support
    We have a SPI Flash Memory attached to our uP and we would like to know if there is a possibility to flash this SPI Memory through JTAG of the uP?
    We don't have the possibility to hook into the SPI bus to use your j-Flash SPI tool. The only way is to controll the SPI bus via the JTAG Interface of the uP.
    Do you have any solution for that?
    Ben
  • Hello Ben,
    Yes, more information can be found here: wiki.segger.com/Programming_External_SPI_Flashes
    For direct mode you can specify the Flash commands in the J-Flash SPI tool.
    For indirect mode over a MCU you can use our open flash loader interface: wiki.segger.com/Adding_Support_for_New_Devices
