Compiler errors in STL with clang
    • Compiler errors in STL with clang
      Hello Segger Team,
      I’m getting some errors when using STL with the CLANG compiler, gcc is working fine. I’ve attached an example to demonstrate this errors.
      You can remove the first error by setting the compiler option -fno-signed-char but I think the project behavior should be same without setting extra options for each compiler.
      Could you take a look at this compiler errors?
      Best Regards
      The post was edited 1 time, last by Masmiseim ().
      The issue was reproducible with the example project. We will investigate further and notify you once we have more information.
      the following compiler options should remove the issues you are seeing.
      In project options add to "Additional C++ Compiler Only Options" add -fno-signed-char and -Wno-narrowing
      This should fix the errors you are seeing.
