[SOLVED] How to disable Linux JLinkRTTClient[Exe] input echo?
  • [SOLVED] How to disable Linux JLinkRTTClient[Exe] input echo?
    Hi there,
    When using JLinkRTTClient[Exe] (not sure if Exe/non-Exe suffixed is not to be used), I seem to get input characters echoed, no matter what I do.
    I usually run it in an xterm window, doing stty -echo -echonl -ctlecho -echoprt beforehand, but the program itself seems to do its own echo anyway.
    That does not happen if I run PuTTY with echo forced off.
    Seems that JLinkRTTClient does not have any command line options about that, and JLinkExe does not have anything about this either.
    Running on Fedora Linux v28, with JLink 6.34h
    The post was edited 1 time, last by david0might ().
    Disabling echo is currently not implemented as the RTTClient is a pure console application so our customers expect echo for input verification.
    However we will discuss it internally if this feature will be added but no promises.
    Alternatively you could use our J-Link SDK and write your own version of RTTClient with echo off option: segger.com/products/debug-prob…nk/technology/j-link-sdk/
