[ABANDONED] CC3220SF running FreeRTOS gets stuck on prvPortStartFirstTask()
  • [ABANDONED] CC3220SF running FreeRTOS gets stuck on prvPortStartFirstTask()
    We are having difficulties when debugging our application based on TI CC3220SF and running FreeRTOS, which gets stuck on call "svc 0" in function "prvPortStartFirstTask()". It succeeds to start the first OS task only sporadically, but works just fine when running without the debugger. Therefore we think that this could be the issue there. We use J-Link with V6.34g SW in JTAG mode together with TI Code Composer Studio v8.2. When the issue occurs, the SVCall handler seems to be installed properly.
    Thanks for any ideas!
    Could you provide a J-Link log of a failing session? wiki.segger.com/Enable_J-Link_log_file
    Does the issue appear when using Ozone isntead of CCS? segger.com/products/development-tools/ozone-j-link-debugger/
