I am using CreateIndirect to populate a dialog box. It seems that I can include 31 widgets but when I add number 32 the call seems to fail. Is there a limit?
Limit to number of widgets in GUI_CreateDialogBox?
There is no limitation regarding the amount of widgets created indirectly (through the GUI_WIDGET_CREATE_INFO structure). I successfully created more than 120 widgets this way.
The only limitation I can think of is the amount of RAM available.
How much memory did you spend emWin?
Does it solve the issue if you increase it?
SvenPlease read the forum rules before posting.
Or you can contact us via e-mail. -
Yep, that did it! The thought crossed my mind and I should have tried it before posting here but I suppose I am in a bit of denial over RAM usage. With FreeRTOS, emWin, and my app so far I have consumed 92% of the PSoC 5LP's available 64K DRAM. I really didn't want to face having to give more to emWin but there isn't a reasonable alternative at this point. Anyway, thanks for the help!
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
