[SOLVED] Jlink and daisy chain issue
  • [SOLVED] Jlink and daisy chain issue
    I have an issue whith Jlink in Jtag daisy chain configuration:
    |JLINK plus| -----TDI------>| RM48 | ------------> | AM3354 |
    | <--- TDO -----------------------------------------|
    when I run the following command :
    1. JLinkGDBServerCLExe -select IP=xx.xx.xx.xx -device RM48L7x -if JTAG -speed auto -ir -jlinkscriptfile JlinkTarget.conf
    with this config file :
    1. void ConfigTargetSettings(void) {
    2. JLINK_SYS_Report("J-Link script file: Manually configuring JTAG chain");
    3. JLINK_JTAG_SetDeviceId(0, 0x3BA00477); // IRLen: 4 AM3354
    4. JLINK_JTAG_SetDeviceId(1, 0x4BA00477); // IRLen: 4 RM48=> CoreSight DAP (This is the one we want to communicate with)
    5. //
    6. // Pre-select CoreSight DAP to be the one J-Link shall communicate with, for this session
    7. //
    8. JLINK_JTAG_IRPre = 4; // Sum of IRLen of all JTAG TAPs preceding the one we want to communicate with
    9. JLINK_JTAG_DRPre = 1; // Number of JTAG TAPs preceding the one we want to communicate with
    10. JLINK_JTAG_IRPost = 0; // Sum of IRLen of all JTAG TAPs following the one we want to communicate with
    11. JLINK_JTAG_DRPost = 0; // Number of JTAG TAPs following the one we want to communicate with
    12. JLINK_JTAG_IRLen = 4; // IRLen of device we want to communicate with
    13. return 0;
    14. }
    I get this error :
    1. <...>
    2. Connecting to J-Link...
    3. J-Link is connected.
    4. Firmware: J-Link Pro V4 compiled Apr 20 2018 16:46:30
    5. Hardware: V4.00
    6. S/N: 174402511
    7. Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    8. Checking target voltage...
    9. Target voltage: 3.27 V
    10. Listening on TCP/IP port 2331
    11. Connecting to target...ERROR: CPU-TAP not found in JTAG chain
    12. ERROR: CPU-TAP not found in JTAG chain
    Is there a wrong thing in my configuration file ?
    Unfortunately both these devices require special JTAG connect handling as they both have a so called TI ICEPICK on board which is also in the JTAG chain and needs to be configured.
    In a "single" device chain J-Link takes care of this themselves.
    However if you daisy chain two different ICEPICK devices together you get a JTAG chain like this: 0: AM3354 1: ICEPICK0 2: RM48 3: ICEPICK1.
    We will discuss this internally if such a setup is possible using a JLinkScript and come back to you.
    For further discussion, would it be OK for you if we contact you on the e-mail address that you registered with on the forum?
    sorry for delay in response. In the meantime we have setup a support ticket system.
    Could you open a ticket at segger.com/ticket for further discussion?
