[SOLVED] Problem importing an Eclipse project
  • [SOLVED] Problem importing an Eclipse project
    I have an ARM Cortex project that builds in NXP's Eclipse environment, MCUXpresso. I would like to import it to SES but run into a problem right away. The importer says that the NXP toolchain is not supported. The NXP toolchain is just their build of gcc, and I would prefer to migrate to the gcc included with SES anyway so that the project could be a completely self-contained Segger project. Is there an easy workaround ?
    If the third party toolchain is not directly supported the importing must be done manually.
    So create a generic project for your target device in Embedded Studio and add all required files to the project.
