[SOLVED] INCLUDE_xTaskGetIdleTaskHandle and INCLUDE_pxTaskGetStackStart required?
  • [SOLVED] INCLUDE_xTaskGetIdleTaskHandle and INCLUDE_pxTaskGetStackStart required?
    The latest SystemView user guide says the following in the FreeRTOS section:
    To get the best results INCLUDE_xTaskGetIdleTaskHandle and INCLUDE_pxTaskGetStackStart should be defined as 1 in FreeRTOSConfig.h.
    I think I may have read somewhere that INCLUDE_pxTaskGetStackStart is no longer required to be set. Is that the case?
    I am not sure about INCLUDE_xTaskGetIdleTaskHandle.
    What difference does defining each of these make, in the latest SystemView and with FreeRTOS v10?
    Thanks.
    These defines are needed so FreeRTOS task switches can be traced more easily.
    For more information we recommend consulting with FreeRTOS support or check the source files.
    It is FreeRTOS version dependent if these settings are required. For V8 and V9 they are recommended. In V10 they do not make a difference.
    But you don't break anything if you enabled it in V10 as well.
    We will update documentation accordingly.
