STM32 and Kinetis MCU in daisy chain
    • STM32 and Kinetis MCU in daisy chain
      Hello!
      I'm trying to program a STM32F446RE and a MKV46F256 CPU via JTAG in daisy chain.
      My setup is this:
      TDI -> STM32F446RE -> MKV46F256 -> TDO
      On Windows I can connect to the STM32, debugging works fine. The MKV46F256 I can't reach. I get the following messages:
      SEGGER J-Link GDB Server V6.34e Command Line Version
      JLinkARM.dll V6.34e (DLL compiled Aug 30 2018 17:36:45)
      Command line: -nosilent -swoport 2332 -select USB=50123300 -telnetport 2333 -singlerun -endian little -noir -speed 1000 -port 2331 -jtagconf 9,2 -powertarget 50 -vd -device MKV46F256xxx16 -if JTAG -halt -reportuseraction
      GDBInit file: none
      Terminal I/O port: 2333
      Generate logfile: off
      Verify download: on
      Init regs on start: off
      Silent mode: off
      Single run mode: on
      J-Link Host interface: USB
      J-Link script: none
      J-Link settings file: none
      Target device: MKV46F256xxx16
      Target interface: JTAG
      Target interface speed: 1000kHz
      Target endian: little
      Connecting to J-Link...
      J-Link is connected.
      Device "MKV46F256XXX16" selected.
      Firmware: J-Link V10 compiled Sep 4 2018 11:24:21
      Hardware: V10.10
      S/N: 50123300
      Feature(s): GDB
      Checking target voltage...
      Target voltage: 3.27 V
      Listening on TCP/IP port 2331
      Connecting to target...InitTarget()
      Connect Under Reset
      Connect Under Reset
      InitTarget()
      Connect Under Reset
      Connect Under Reset
      ERROR: InitTarget(): PCode returned with error code -1
      ERROR: Could not connect to target.
      Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
      Shutting down...
      Please check power, connection and settings.
      JTAG scan looks like this:
      Connecting to target via JTAG
      TotalIRLen = 13, IRPrint = 0x0211
      JTAG chain detection found 3 devices:
      #0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
      #1 Id: 0x06421041, IRLen: 05, STM32 Boundary Scan
      #2 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
      What could be wrong?
      Konrad
    • Hello Konrad,
      When setting up your daisy chain connections, did you consider the design recommendations when chaining Kinetis devices?
      wiki.segger.com/Kinetis_Series…e_devices_in_a_scan-chain
    • Hi Nino,
      here is an update. In the meantime I can debug my Kinetis application in daisy chain.
      I'm using a script with my own (empty) InitTarget() function. It looks like this:
      void InitTarget(void) {
      JLINK_SYS_Report("custom INIT for MKV46F256");
      I don't know what the original Init function does, can I use this workaround whith any drawbacks?
      Konrad
    • Hello Konrad,
      The connect sequence for Kinetis devices is rather "tricky" so the default behaviour in J-Link software is to assume that if JTAG is used the Kinetis device is first in the JTAG chain.
      This is obviously not the case in your setup.
      For the ST device these special handling is not needed so connect works with the settings you pick externally.
      What we can offer you is to provide you with the connect sequence so you can overwrite the default behaviour for your custom JTAG chain with the Kinetis device.
      For that I will PM you contact information.
