SEGGER_SYSVIEW_PrintfHost formatting on host?
    • SEGGER_SYSVIEW_PrintfHost formatting on host?
      Dear all,
      I tried to use the SEGGER_SYSVIEW_PrintfHost() function. My understanding is that:
      unsigned int c = 10;
      SEGGER_SYSVIEW_PrintfHost("1: %d\n",c);
      should lead to an output in the terminal window like: 1: 10
      However I always get: 1: %d
      So the formatting on the host seems not to work in my configuration. Did I need to define or compile additional RTT functionality to get it work? The examples that comes with SystemView seems not to use the formatting string. The define of SEGGER_SYSVIEW_PRINTF_IMPLICIT_FORMAT is set to 0 in my configuration file.
      Any idea what I need to change?
      Best Regards
      Markus
    • Hello Markus,
      Your understanding is correct. We just tried to reproduce the issue with SystemView V2.52c and our embOS BSP for the Cortex-M Trace Reference Board and the string was output correctly as "1: 10".
      Which version of SystemView are you currently using? Does using the latest version change the behaviour?
