Debugging stops with: Error reading from memory
    • Debugging stops with: Error reading from memory
      I am using an NRF52 board with SEGGER studio V3.5 and JLINK (latest firmware) on MAC OSX. I am seeing an intermittent issue where the debug session terminates with a dialog box displaying "Error reading from memory". It is not consistent but happens with some regularity.
      Any ideas what might be causing this?
      Does your application use any low power modes or WFIs ?
      Could you provide a J-Link log file of the failed session?
