J-Flash hidden, but with progress window? J-flash like ops from Commander?
    • J-Flash hidden, but with progress window? J-flash like ops from Commander?
      I have a setup that I will be deploying soon that is using J-Flash to do an operation with a custom flash loader.
      These are just last details, to get it set up in the "best" way:
      Presently, I can get J-Flash to start, do production programming, and then exit with:
      JFlash.exe -loadprj.\myproject.jflash -auto -exit
      and I can make JFlash run in "hidden" mode with"
      JFlash.exe -loadprj.\myproject.jflash -auto -hide -exit
      But when using -hide, there is nothing shown on-screen at all. Is there a way to get only the pop-ups showing the actions and progress bars?
      Alternately, if there was a way to accomplish the same actions done in J-Flash via the plain J-Link commander, I could write a script to do the equivalent with the hope that the Commander style popup's would be shown.
      But I have not found any option to load into a specific flash bank (and thus invoke the custom flash loader) with JLink.
      Additionally, the bank that I am flashing into does not share the main micro's address space (and actually overlaps it). In the case of using the J-Flash GUI, the internal flash bank is fully disabled.
      Do those options exist in Commander?
      A partial hide is not implemented. Either the GUI is completely on or off.
      J-Link Commander is not meant as a production tool so it only has basic functionality in that regard. So to program a device command loadfile might be used where you can specify the address to program the application to. If everything is set correctly J-Link should program the correct bank. More information can be found in the J-Link user guide.
      However if you are looking into more flexibility and control -> J-Flash.
    • Interesting.
      Will J-Link support OpenFlashLoader loaders, if they are added to the XML file?
      I remapped the external flash bank to a base of 0xC0000000, which is unused on my micro, in both the FlashDev.c and in the XML file.
      J-Flash works as expected when operating from these addresses, but J-Link commander only returns "Could not read memory" when trying:
      mem 0xC0000000,0x1FF
      Yes, that's the whole point and only way to add them globally to all applications using the J-Link software.
      Which entries to you get in the J-Link Control Panel in the "Flash" tab? Is the memory at 0xC... visible there?
