[SOLVED] J-Link programming error on Microchip SAML11 Cortex-M23 (RXN issue?)
  • [SOLVED] J-Link programming error on Microchip SAML11 Cortex-M23 (RXN issue?)
    I have soldered a SAML11D15A to an SSOP breakout board and am trying to get some simple Atmel Studio 7 Example code to run on it.
    I am using a J-Link Edu Mini with the latest firmware and the J-Link DLL is V6.34c.
    I have followed the instructions on the Segger wiki to attempt to clear the RXN bit in the User Row to enable RAM execution of the re-flashing algorithm but this does not appear to work.
    The J-Link can initially see a fresh SAML11D15A part running running from the internal 4MHz oscillator:
    TIF>S
    Speed>400
    Device "ATSAML11D15A" selected.
    Connecting to target via SWD
    InitTarget()
    Found SW-DP with ID 0x0BF11477
    AP[0]: AHB-AP (IDR: 0x04770025)
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0x41003000
    CPUID register: 0x411CD200. Implementer code: 0x41 (ARM)
    Found Cortex-M23 r1p0, Little endian.
    FPUnit: 4 code (BP) slots and 0 literal slots
    Security extension: implemented
    Secure debug: enabled
    CoreSight components:
    ROMTbl[0] @ 41003000
    ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4CB ROM Table
    ROMTbl[1] @ E00FF000
    ROMTbl[1][0]: E000E000, CID: B105900D, PID: 000BBD20 Cortex-M23
    ROMTbl[1][1]: E0001000, CID: B105900D, PID: 000BBD20 DWT
    ROMTbl[1][2]: E0002000, CID: B105900D, PID: 000BBD20 FPB
    Cortex-M23 identified.
    I then make a copy of 0x44 User Row bytes from 0x804000 and modify byte 5 from 0xF8 to 0xF0 (see J-Flash screenshot for before and after file modification and then after the erasing and re-writing process):
    J-Link>savebin e:\m23-before.bin, 0x00804000, 0x44
    Opening binary file for writing... [e:\m23-before]
    Reading 68 bytes from addr 0x00804000 into file...O.K.
    And then Erase the User Row at 0x804000:
    J-Link>w4 0x4100501C 0x00804000
    Writing 00804000 -> 4100501C
    J-Link>w2 0x41005000 0xA502
    Writing A502 -> 41005000
    A problem occurs trying to write the modified binary file back into the User Row:
    J-Link>loadbin e:\m23-after.bin, 0x804000
    Downloading file [e:\m23-after.bin]...
    ****** Error: Timeout while checking target RAM, RAMCode did not respond in time. (PC = 0xFFFFFFFF, CPSR = 0xFFFFFFFF, LR = 0x01000003)!
    Failed to prepare for programming.
    Failed to execute RAMCode for RAM check!
    Unspecified error -1
    This appears to be game over as far as the chip is concerned as the User Row is now all 0xFF's and the J-Link can no longer connect to it:
    TIF>S
    Speed>400
    InitTarget()
    Cold-Plugging detected
    InitTarget()
    InitTarget()
    InitTarget()
    Cannot connect to target.
    Afterwards, the part cannot be seen in Atmel Studio 7 - see attached dialog box Error message.
    Having failed to get this procedure to work on 2 intially good SAML11D15A parts, I'd like to establish some instructions from SEGGER that work.
  • I did some more research on this issue.
    This time I used the J-Link Mini Edu on a SAML10E15A device (this is the part without the Trustzone security features) and ran the same procedure to clear the RXN bit:
    J-Link>connect
    Device "ATSAML10E15A" selected.
    InitTarget()
    AP[0]: Core found
    J-Link>savebin e:\l10-urow.bin 0x00804000, 0x40
    Opening binary file for writing... [e:\l10-urow.bin]
    Reading 64 bytes from addr 0x00804000 into file...O.K.
    J-Link>w4 0x4100501C 0x804000
    J-Link>loadbin e:\l10-fixed.bin, 0x804000
    Halting CPU for downloading file.
    Downloading file [e:\l10-fixed.bin]...
    J-Link: Flash download: Bank 1 @ 0x00804000: 1 range affected (256 bytes)
    J-Link: Flash download: Total time needed: 0.158s (Prepare: 0.111s, Compare: 0.008s, Erase: 0.000s, Program: 0.015s, Verify: 0.001s, Restore: 0.022s)
    O.K.
    J-Link>w2 0x41005000 0xA504
    Writing A504 -> 41005000
    This time the loadbin call doesn't fail with a timeout. So something must be going wrong with the L11 NVM programming algorithm.
    I also discovered that I could recover both of my previously 'bricked' L11D15A devices to a useable state by using an Atmel ICE debugger to perform a Chip Erase 2 (i.e. erase everything) so it looks like the issue is specific to the SEGGER J-Link.
    Setting and resetting the RXN bit on our eval boards we have in house always worked flawlessly.
    For further convenience J-Link software will offer to set the bit automattically when connecting to a SAML11 with the next J-Link software release planned by the end of the week.
    To stay up to date we suggest subscribing to our update notification list: segger.com/notification/subscribe.php?prodid=7,94
  • Hello Nino,
    I removed the old DLL and installed V6.34f.
    I still observe the same issue.
    I also tried my Segger J-Link Mini Edu on a SAML11 Xplained Pro board and observe the same issue on it too.
    The only reason I can think of why the issue is not known to SEGGER is that you have never encountered an L11 that has RXN=1 at the start which is how they are supplied from the factory.
    As you will know, the commands on your L11 wiki page:
    Reformat the User Row such that:
    J-Link>mem 0x804000, 0x40
    00804000 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    00804010 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    00804020 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    00804030 = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    This sets RXN=1 and means the savebin flash algorithm cannot run in on-chip SRAM.
    Resarf
  • Hello again Nino,
    Out of curiosity, I removed V6.34f and installed the beta of V6.35c.
    It updates the firmware on the J-Link Edu Mini to September 7, 2018.
    Everything works in J-Link commander now and I see the dialog box about the RXN bit.
    The only remaining issue is to fix the Chip Erase All (CE2) error in Atmel Studio 7 when using the J-Link Edu Mini as the SWD programmer (see attached screenshot).
    Resarf
  • Hello Resarf,
    Great to hear that everything is working with J-Link Commander again.
    As you already found out the fix is only part of the beta currently and will be part of the next full release.
    Regarding the Atmel Studio error, such an issues is not known to us.
    Make sure to use the latest version of Atmel Studio and that the J-Link beta DLL is also running in Atmel Studio.
    Should you still run into errors we suggest getting in contact with Microchip support.
