Text is not displayed correctly
    • Text is not displayed correctly
      I try to display text using GUI_DispStringAt() but it looks not ok on my LCD (see attachment). All other graphical elements (circles, lines, rectangles, ...) are ok.
      What could that be? Whats wrong?
      Here is the source:
      1. GUI_Init();
      2. if (GUI_ALLOC_GetNumFreeBytes() < (1024L * 5))
      3. {
      4. GUI_ErrorOut("Not enough memory available.");
      5. return 0;
      6. }
      7. GUI_SetBkColor(GUI_BLUE);
      8. GUI_Clear();
      9. GUI_SetColor(GUI_WHITE);
      10. //GUI_SetTextMode(GUI_TEXTMODE_TRANS);
      11. GUI_SetFont(GUI_FONT_24_1);
      12. GUI_DispStringAt("0123456789 ABCDEFG", 10, 200);
      13. GUI_DispCharAt('A', 400, 200);
      14. GUI_SetFont(GUI_FONT_8X16);
      15. GUI_DispCharAt('A', 430, 200);
      Thanks!!!
      Which device are you using?
      Can you attache your LCDConf.c, GUIConf.c and GUIConf.h?
      It looks a bit like you the data is getting cached and not written through to the framebuffer.
      But this is just a guess.
    • Has nobody an idea? Please!!
      It seems to be that the library dont use the resolution from the display. If I draw a line, e.g.
      1. GUI_DrawLine(300, 300, 310, 310);
      then I would expect a fine line with 10 pixels, but I see only 3 big rectangles diagonally to each other.
      Another observation:
      If I set only one Pixel with GUI_DrawPixel(300, 300) then this pixel looks like a small horizontal line. If I set the pixel directly to the right (GUI_DrawPixel(301, 300)), nothing happens. If I put this pixel in a different color, I can see that the pixel on (300,300) is completly overwritten with this pixel. This is the same for (302,300) and (303,300). Only the pixel (304,300) is displayed as a new pixel.
      What's wrong? I have a physical resolution of 800 x 480 and it seems that the library only uses 200 x 480 pixel!
      The post was edited 4 times, last by hans405 ().
      This sound a bit like an LCD controller which is not properly initialized. Some controller have a stride register which defines the width of the framebuffer in bytes. If the settings for such a register do not fit the user will experience a behavior as you describe.
      Unfortunately, the LCDConf.c posted by you includes no LCD controller initialization.
    • Here is my LCD Initialization:
      1. /* LTDC init function */
      2. static void MX_LTDC_Init(void)
      3. {
      4. LTDC_LayerCfgTypeDef pLayerCfg;
      5. LTDC_LayerCfgTypeDef pLayerCfg1;
      6. hltdc.Instance = LTDC;
      7. hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
      8. hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
      9. hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
      10. hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IIPC;
      11. hltdc.Init.HorizontalSync = 127;
      12. hltdc.Init.VerticalSync = 1;
      13. hltdc.Init.AccumulatedHBP = 215;
      14. hltdc.Init.AccumulatedVBP = 34;
      15. hltdc.Init.AccumulatedActiveW = 1015;
      16. hltdc.Init.AccumulatedActiveH = 514;
      17. hltdc.Init.TotalWidth = 1055;
      18. hltdc.Init.TotalHeigh = 524;
      19. hltdc.Init.Backcolor.Blue = 0;
      20. hltdc.Init.Backcolor.Green = 0;
      21. hltdc.Init.Backcolor.Red = 0;
      22. if (HAL_LTDC_Init(&hltdc) != HAL_OK)
      23. {
      24. _Error_Handler(__FILE__, __LINE__);
      25. }
      26. pLayerCfg.WindowX0 = 0;
      27. pLayerCfg.WindowX1 = 800;
      28. pLayerCfg.WindowY0 = 0;
      29. pLayerCfg.WindowY1 = 480;
      30. pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
      31. pLayerCfg.Alpha = 200;
      32. pLayerCfg.Alpha0 = 100;
      33. pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
      34. pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
      35. pLayerCfg.FBStartAdress = 0x64000000; //SDRAM_BANK1_ADDR_IBANK0;
      36. pLayerCfg.ImageWidth = 800;
      37. pLayerCfg.ImageHeight = 480;
      38. pLayerCfg.Backcolor.Blue = 0;
      39. pLayerCfg.Backcolor.Green = 200;
      40. pLayerCfg.Backcolor.Red = 0;
      41. if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
      42. {
      43. _Error_Handler(__FILE__, __LINE__);
      44. }
      45. pLayerCfg1.WindowX0 = 0;
      46. pLayerCfg1.WindowX1 = 0;
      47. pLayerCfg1.WindowY0 = 0;
      48. pLayerCfg1.WindowY1 = 0;
      49. pLayerCfg1.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
      50. pLayerCfg1.Alpha = 0;
      51. pLayerCfg1.Alpha0 = 0;
      52. pLayerCfg1.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
      53. pLayerCfg1.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
      54. pLayerCfg1.FBStartAdress = 0;
      55. pLayerCfg1.ImageWidth = 0;
      56. pLayerCfg1.ImageHeight = 0;
      57. pLayerCfg1.Backcolor.Blue = 0;
      58. pLayerCfg1.Backcolor.Green = 0;
      59. pLayerCfg1.Backcolor.Red = 0;
      60. if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg1, 1) != HAL_OK)
      61. {
      62. _Error_Handler(__FILE__, __LINE__);
      63. }
      64. // __HAL_LTDC_LAYER_ENABLE(&hltdc, 0);
      65. }
      Interesting: If I initialize the variable "pLayerCfg.FBStartAdress" with the correct address (SDRAM_BANK1_ADDR_IBANK0), then I have the described behavior. When I set this variable to a wrong address (e.g. 0x64000000), then it works! But why?!
      this looks a bit like the problem you describe.
      Try to confiogure the MPU if your device got one.
