[SOLVED] Segger Studio frozen on "Building", after failed attempted at GIT
  • [SOLVED] Segger Studio frozen on "Building", after failed attempted at GIT
    Earlier today I attempted to integrate GIT with Segger Studio but did not go through with it. Eventually, the Studio got stuck on "Bulding" and I had to close it from the task manager and give up on the GIT integration. I tried to open a project again after some time and now it does not continue forward from the first page and has "Building" written on the top bar, no matter which project I open.
    In addition to that, I uninstalled and installed the program but the problem is the same. The only way to close the program is through task manager, it is totally frozen. Also restarted the PC. How to fix this?
    Windows 10, SES 3.5
    The post was edited 2 times, last by devops ().
    Your emproject file got most likely corrupted. If you rename it, can you open Embedded Studio again?
    How to implement version control software in Embedded Studio is explained here: wiki.segger.com/Embedded_Studio_VCS_configuration
  • Thank you for your reply. Renaming the .emproject file does not solve the issue + I am not able to open any projects, no matter their name or location. The Studio just freezes up, even after the reinstall. Should I uninstall and delete some "special" folders somewhere?
    In that case try to delete the settings.xml in the ES user folder located in the AppData directory.
    AppData\Local\SEGGER\SEGGER Embedded Studio\v3
    Does that solve the issue?
