In few regions, comma is used as decimal separator instead of decimal point ( Eg: CZech). Does Emwin have any option to handle these decimal separator based on language ?
Decimal separators in Emwin
Or you can contact us via e-mail. -
Thank you. I will try this API.
Every time before displaying the value I need to call this API. If I have some 20 widgets showing floating point value, This API must be called each and every time. Is that correct? -
Of course not, I just wanted to say that you have to call it before the first time you display a floating value.
Just once after GUI_Init() and the new separator will be used every time you display a float value.
SvenPlease read the forum rules before posting.
GUI_SetDecChar(',') will work only if I use api like GUI_DispFloat(). Is that correct?
I am displaying values using API GUI_DispStringInRect(), Since I need to show the value at particular position on custom button.
Please check the Code is shared below:
void YButnCallBack(WM_MESSAGE *pMsg)
GUI_RECT rect0 = { 10,10,255,70 };
GUI_RECT rect1 = { 256,10,330,70 };
GUI_RECT rect2 = { 331,10, 380,70 };
char strY[5];
snprintf(strY, sizeof(strY), "%.1f", Ysize); // (YSize is float variable that will keep changing)
switch (pMsg->MsgId)
case WM_PAINT:
if (BUTTON_IsPressed(pMsg->hWin))
GUI_SetBkColor(AZURE_BLUE);
GUI_Clear();
GUI_SetFont(FONT_16);
GUI_SetColor(GUI_BLACK);
GUI_DispStringInRect("Y:", &rect0, GUI_TA_LEFT | GUI_TA_BOTTOM);
else
GUI_SetBkColor(GUI_BLACK);
GUI_Clear();
GUI_SetColor(AZURE_BLUE);
GUI_SetColor(LIGHT_GREY);
GUI_DispStringInRect("cm", &rect2, GUI_TA_RIGHT | GUI_TA_BOTTOM);
GUI_SetFont(FONT_25);
GUI_DispStringInRect(strY, &rect1, GUI_TA_RIGHT | GUI_TA_BOTTOM);
break;
default:
BUTTON_Callback(pMsg);
break;
In my personal opinion, you do not need to call the GUI_SetDecChar, you have already keep the YSize in the string, so why not to write a function to change "." to ",". this is much faster to solve your problem. -
if you call GUI_DispStringInRect() it simply displays the string you pass to the function. This is independent of emWin and it is up to you what is inside the the string.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
