Layer[1] displays in GUICC_M8888I but not M565
    • Layer[1] displays in GUICC_M8888I but not M565
      Hi
      I've been using two layers on STM32F4 with the configuration for both layers
      #define LTDC_X_COLORCONVERION GUICC_M8888I
      #define LTDC_X_DISPLAYDRIVER GUIDRV_LIN_32
      Layers are in SDRAM, each in its own bank. Screen is 800x480.
      My LTDC frame refresh is low using this configuration so I tried a change to this
      #define LTDC_X_COLORCONVERION GUICC_M565
      #define LTDC_X_DISPLAYDRIVER GUIDRV_LIN_16
      However, now my background layer does not show. The primary layer shows correctly. I have not changed any other configuration, just the ColorConversion and DisplayDriver. I am using the driver template stm32f4x9i_eval_mb1046.c
      I've tried a number of changes (different conversions and drivers) but have ran out of thoughts on what to try.
      I can change to soft-layer and could even live with the low refresh rate but am wondering if you have any advice for where I could look or what I could change?
      Mark
      How big is the is the second layer?
      If the layer with color conversion M565 is covering the other layer completely, the background layer can't be visible. The color conversion GUICC_M565 doesn't support transparency. You could use GUICC_M1555I, there you will have one bit indicating transparent pixels and 15 bit for color information.
    • Hi Sven,
      Sorry for the delay in responding. I have been travelling.
      Both layers are the same size (800x480). I understand the issue of transparency when the emWin library is stacking objects or layers and will have a look at this again. Maybe I am misunderstanding the use of VRAM switching for layers in the mb1046-style driver for the 32F429I as I did not think transparency is an issue for the two hardware (vram) layers implemented. I thought they got painted no-matter-what as the vram is RGB info only and no transparency. So, more testing.
      To be honest I stopped looking at this as I tracked down the slow frame paint issue to another issue. I am posting a Q on this separately,
