I have a Segger ATE system with two modules. I can FTP into mainboard but do not see modules in directory, I cannot see modules in web server as well
[SOLVED] Segger ATE main board not recognizing modules
are the module's PWR LEDs lit?
If they are not, most likely the output voltage of your power supply is not stable enough or not in the allowed range of 4.8V to 5.25V.
The web server will show information about the power status on "Flasher ATE status".
ArnePlease read the forum rules before posting.
Or you can contact us via e-mail. -
The LED's are not on
I will verify voltage one more time but I think it was very close to 5
Anything else I can check? -
The power leds briefly flash when power is turned on the quickly go out. About a 50 mS flash.
The power requirements for now are 4.8V to 5.25V. The power supply needs to keep the supply
voltage in this range, otherwise the modules will automatically be powered down.
We will change the requirements to 4.4V to 5.25V for the next firmware release.
Do you have a better power supply available for now?
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
Tags
