Jlink Version 6.34, GDB connection error: Reply contains invalid hex digit 32
    • Jlink Version 6.34, GDB connection error: Reply contains invalid hex digit 32
      Hello sirs,
      I use JLinkGDBServerCL.exe and arm-none-eabi-gdb.exe to debugging the my LPC boards, but the gdb cannot connect to the gdbserver due to "Reply contains invalid hex digit 32".
      The boards both used the JLink CDC firmware. I tried the old versions no such issue. Looks like this is a bug.
      JLink version: 6.34
      OS: windows10 & windows 7
      1. Start GDBServer
      Shell-Script
      1. JLinkGDBServerCL.exe -select usb=723160793 -if SWD -speed auto -device LPC54114J256_M4 -port 3400 -singlerun -strict
      2. Start GDB
      1. C:\Dpc\stationscript>C:/PROGRA~2/GNUTOO~1/62017-~1/bin/AR470E~1.EXE --exec C:/Dpc/.workspaces/lpcxpresso54114@1/cmsis_i2c_dma_b2b_transfer_master.out
      2. GNU gdb (GNU Tools for ARM Embedded Processors 6-2017-q2-update) 7.12.1.20170417-git
      3. Copyright (C) 2017 Free Software Foundation, Inc.
      4. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
      5. This is free software: you are free to change and redistribute it.
      6. There is NO WARRANTY, to the extent permitted by law. Type "show copying"
      7. and "show warranty" for details.
      8. This GDB was configured as "--host=i686-w64-mingw32 --target=arm-none-eabi".
      9. Type "show configuration" for configuration details.
      10. For bug reporting instructions, please see:
      11. <http://www.gnu.org/software/gdb/bugs/>.
      12. Find the GDB manual and other documentation resources online at:
      13. <http://www.gnu.org/software/gdb/documentation/>.
      14. For help, type "help".
      15. Type "apropos word" to search for commands related to "word".
      16. (gdb) target remote localhost:3400
      17. Remote debugging using localhost:3400
      18. Reply contains invalid hex digit 32
      19. (gdb)
      haley
    • JLinkGDBServerCL.exe console output
      1. JLinkARM.dll V6.34 (DLL compiled Aug 7 2018 15:52:23)
      2. Command line: -select usb=723160793 -if SWD -speed auto -device LPC54114J256_M4 -port 3400 -singlerun -strict
      3. -----GDB Server start settings-----
      4. GDBInit file: none
      5. GDB Server Listening port: 3400
      6. SWO raw output listening port: 2332
      7. Terminal I/O port: 2333
      8. Accept remote connection: localhost only
      9. Generate logfile: off
      10. Verify download: off
      11. Init regs on start: off
      12. Silent mode: off
      13. Single run mode: on
      14. Target connection timeout: 0 ms
      15. ------J-Link related settings------
      16. J-Link Host interface: USB
      17. J-Link script: none
      18. J-Link settings file: none
      19. ------Target related settings------
      20. Target device: LPC54114J256_M4
      21. Target interface: SWD
      22. Target interface speed: auto
      23. Target endian: little
      24. Connecting to J-Link...
      25. J-Link is connected.
      26. Firmware: J-Link LPCXpresso V2 compiled Sep 23 2016 12:14:15
      27. Hardware: V1.00
      28. S/N: 723160793
      29. Checking target voltage...
      30. Target voltage: 3.30 V
      31. Listening on TCP/IP port 3400
      32. Connecting to target...Connected to target
      33. Waiting for GDB connection...Connected to 127.0.0.1
      34. GDB closed TCP/IP connection
      35. Restoring target state and closing J-Link connection...
      36. Shutting down...
      Keep in mind that this here is no support forum. If you have pressing mattes (especially as a silicon vendor) we recommend using our official support channels, more information can be found in my signature.
      In your case it would be best if everything gets coordinated over Ruth.
