Ozone: repeated crashes on MacOS
    • Ozone: repeated crashes on MacOS
      I am having frequent crashes running Ozone on MacOS (Sierra and High Sierra).
      These always seem to happen in the same place.
      They happen either when trying to view the members of a C++ object in my program, or when starting a previously-run session.
      I'm attaching a couple of crash logs.
      The 08-05 one was from 2.57c(beta), but I've also tried a couple of other (beta and non-beta) versions with the same results.
      Could you provide us with your elf file for reproduction purposes?
      On which object members does this issue appear on exactly?
      Quick update. Our Ozone department informed me that this issue should be fixed in the current Ozone release version V2.56t.
      Could you give it a try and report back if everything is working now?
