[SOLVED] Different target behavior when use J-link Pro and ST-LINK programmers
  • [SOLVED] Different target behavior when use J-link Pro and ST-LINK programmers
    I see issue when I try to work with different HW boards. It is the same boards, but just several exemplars.
    When I switch to other exemplar of target HW (with older FW in flash), as a result I see CPU in some hard fault or in other OS configASSERT trap. There .gdb log shows that all Downloads are verified with OK mark.
    I'm a little bit confused that same .elf files have different behavior based on debugger selection.
    Also, after programming target HW by ST-LINK, I able correctly work with target board.
    Used SW and HW:
    SEGGER J-Link GDB Server V6.32i Command Line Version
    Firmware: J-Link Pro V4 compiled Apr 20 2018 16:46:30
    I do not use RTOS extension/plugin in this case.
    I'm use SWD interface with SWDIO, SWCLK, GND, VTref, nRESET
    described here segger.com/products/debug-prob…gy/interface-description/
    Is there a correct load of two .elf files in attached startup scripts? (bootloader + App)
    Another important note: The bootloader part is the same in different FW versions, located in first 48K (3 blocks).
    Target MCU: STM32F429VE
    What could be wrong?
    The post was edited 2 times, last by Aseris ().
    Such an issue is not known to us and we see no issues with your script.
    For verification we suggest the following test:
    1. Program the device using ST-Link.
    2. Read back the entire device memoryusing J-Link and J-Flash sofware.
    3. Erase chip.
    4. Pogram Chip using J-Link.
    5. Read back entire device with J-Flash again.
    6. Compare the read back files.
    Are the read back files equal?
  • After proposed flow, I do it, then realize that bootloader is missing, and I double check my startup scripts, in J-link version it was a typo in path.
    Instead of load ADV2_BL.elf I had load ./Debug/Application.elf . Two times load only application.
    It can be marked as solved.
