[SOLVED] error Remote 'g' packet reply is too long: ........
  • [SOLVED] error Remote 'g' packet reply is too long: ........
    I am experiencing a problem when i try to start debuging using a JLink Edu and JLink GDB server combination.
    When I start to debug i get the following error
    My development environment is
    Visual Studio 2013 using VisualGDB
    Segger JLink Edu
    Segger GDB (cli) server
    Target = PIC32MX795F512H
    Target Interface = ICSP
    PCB = custom
    I have confirmed that i can use the JLink successfully with the custom PCB in the MplabX Development environment provided by Microchip (using the dll/pluggin to control the debugger and not the GDB server)
    I have contacted VisualGDB regarding this issue and they told me to contact Segger about it as it looks like an incompatability between the Segger GDB stub and the toolchain I am using.
    Can anyone recomend a way to resolve this problem?
    Stuart
  • Hello Stuart,
    Could you provide a screenshot of a J-Link Commander connect?
    Which J-Link software version and VisualGDB version are you using?
  • Hello Nino,
    I am using JLink v6.32h and Visual GDB version 5.4(preview 3, build 2332)
    I am also using Microchips xc32 V2.05 compiler
    I have attached the output of Jlink commander when it has connected and the version screen of visual GDB.
    Thanks for your help
    Stuart
  • Hello Stuart,
    Unfortunately GDB for PIC32 is not implemented for J-Link software due to low demand.
    Currently only MPLAB is supported which you already confirmed is working.
  • Hi Nino,
    Thanks or gettting back to me. Its probably of no surprise that that news is very disappointing to me. Maybe you could pass on some feedback to the appropriate people for me. Could you let them know that if they say that PIC32 is supported, it actually is fully supported like the other devices, not just partially supported and its up to the customer to discover what combinations work.
    So, is there any expectation that PIC32 support will be implemented in the near future? Keeping in mind, if it is implemented, it will give microchip developers an alternative (JLink,VisualGDB and VisualStudio) to using MplabX. If you have ever used MplabX, you would understand what an attractive proposition that would be!
    Looking forward to Segger's response.
    Stuart
  • Hello Stuart,
    Totally understandable, having alternatives is always a good thing. However the PIC32 market is simply to small compared to the Arm market. Please understand that it is not in our interest to invest significant time and effort on adding additional features that we won't get directly or indirectly revenue from, especially considering follow up support.
    So at the current point in time there are no plans to expand PIC32 support in our ecosystem.
