hi I created a dialog box and took handle. On press of button in that dialog box new dialog will be created and previous one was deleted using GUI_EndDialog. now I want to check if the previous dialog box handle is valid or not for that i am checking WM_IsWindow() api. which will return 1 if window handle is valid else will return 0. which is fine.
When a handle got deleted but still it holds some value what is that value? is it an address or some value.
Before using WM_IsWindow() i used WM_IsVisible api but this api is returning 1 even if that handle is deleted. can you please explain the difference?
