[SOLVED] Absolute File Paths - Find and Replace - 3.40
  • [SOLVED] Absolute File Paths - Find and Replace - 3.40
    I downloaded ES version 3.40 and I am having one issue that is hard to find a good work around.
    In the find and replace window, results now show up with their (very long!) absolute path. This makes it much harder to read the search results.
    The same project in 3.34a finds the results listed very neatly underneath each *.c or *.h file.
    Do I have a setting set differently in 3.40 that makes it search this way?
    Thanks!
    You can switch to the "old" view under Tools->Options->Environment->Flat Search Result Output-> No
    Now it should look like before.
