I’m trying to test the FE310 softcore on Arty Artix-7 35T board with some programs with J-Link EDU. I followed carefully the instructions from wiki.segger.com/SiFive_Arty_FPGA_Dev_Kit for the hardware connection and freedom studio setup. The default program coupled with the bitstream works fine. However, when I tried to download with J-link a new RISV-V program (e.g. the drhystone example), the following error appeared:
SEGGER J-Link GDB Server V6.33g (beta) Command Line Version
JLinkARM.dll V6.33g (DLL compiled Jun 28 2018 15:09:48)
Command line: -if jtag -device RISC-V -endian little -speed 4000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: on
Init regs on start: on
Silent mode: off
Single run mode: on
Target connection timeout: 0 ms
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
Target device: RISC-V
Target interface: JTAG
Target interface speed: 4000kHz
Target endian: little
Connecting to J-Link…
J-Link is connected.
Firmware: J-Link V10 compiled Jun 27 2018 10:57:29
Hardware: V10.10
S/N: 260109090
OEM: SEGGER-EDU
Feature(s): FlashBP, GDB
Checking target voltage…
Target voltage: 3.27 V
Listening on TCP/IP port 2331
Connecting to target…
J-Link found 1 JTAG device, Total IRLen = 5
JTAG ID: 0x20000001 (RISC-V)
Connected to target
Waiting for GDB connection…Connected to 127.0.0.1
Reading all registers
Reading register (PC = 0x00000000)
Received monitor command: speed 4000
Target interface speed set to 4000 kHz
Received monitor command: clrbp
Received monitor command: reset
Resetting target
Received monitor command: halt
Halting target CPU…
…Target halted (PC = 0x404002CA)
Received monitor command: regs
X0 = 00000000, X1 = 4040010A, X2 = 8000FFE0, X3 = 800007C0
X4 = 00000000, X5 = 00000000, X6 = 00000010, X7 = 404007C0
X8 = 01484812, X9 = 00000000, X10= 01484817, X11= 00000000
X12= 014849A2, X13= 00000000, X14= 000000FF, X15= 00000000
X16= 0200C000, X17= 00000000, X18= 02000080, X19= 00000000
X20= 00000000, X21= 00000000, X22= 00000000, X23= 00000000
X24= 00000000, X25= 00000000, X26= 00000000, X27= 00000000
X28= 20005000, X29= 0000002F, X30= 000000FF, X31= 00000000
PC = 404002CA
Reading register (PC = 0x404002CA)
Received monitor command: flash breakpoints 1
Flash breakpoints enabled
Downloading 108 bytes @ address 0x40400000 - Verify failed
Downloading 2534 bytes @ address 0x4040006C - Verify failed
Downloading 59 bytes @ address 0x40400A54 - Verify failed
Downloading 44 bytes @ address 0x40400A90 - Verify failed
Downloading 1072 bytes @ address 0x40400ABC - Verify failed
Writing register (PC = 0x40400000)
Reading register (MISA = 0x40101105)
Read 2 bytes @ address 0x40400552 (Data = 0x2020)
Resetting target
Halting target CPU…
Reading 64 bytes @ address 0x01484800
WARNING: Failed to read memory @ address 0x01484800
Read 4 bytes @ address 0x0148480E (Data = 0x24232423)
PC = 404002CA
Setting breakpoint @ address 0x40400552, Size = 2, BPHandle = 0x0001
Starting target CPU…
And it just stuck at Starting target CPU… and apparently the program was not flashed to QSPI Flash as I pushed the reset button.
I can't find why download verify failed as shown in the log.
Could someone please help shed some lights?
GDBInit file: none
Verify download: on
Silent mode: off
Single run mode: on
J-Link script: none
Hardware: V10.10
S/N: 260109090
OEM: SEGGER-EDU
Connected to target
Resetting target
Halting target CPU…
PC = 404002CA
Resetting target
Halting target CPU…
PC = 404002CA
