[SOLVED] SES missing header files
  • [SOLVED] SES missing header files
    Hi, I have following issue and need some help.
    I am using SEGGER Embedded studio for ARM Release 3.4 build 2018052200 36079 with latest nordicc's nRF_SDK_for_Thread_v0.11.0_84a130f on window 10 (64).
    I can compile <Thread SDK>/examples/thread/experimental/cli/usb without any errors BUT When I run it by pressing <Go command> on SES studio the File explorer window pops up, indicating "missing file". Add or remove for future. It shows up for several files. Which some o these file don't even exists.
    Upon search i found following post "Debugging OpenThread example with Segger"
    https://devzone.nordicsemi.com/f/nordic-q-a/35344/debugging-openthread-examples-with-segger/135942#135942.
    Per this post it indicates there are some issues with the latest SES development environment and suggest ignoring these messages as these source file are not needed for already compiled libraries.
    I was able to follow this and run the program. is this the right way?
    According to the Nordic SDK release notes the SDK has been tested with Embedded Studio V3.34. Other versions might need slight modifications. As the SDK is maintained by Nordic we suggest getting in contact with Nordic Semi support in that regards.
