[ABANDONED] Ozone: Target.WriteU32 bug
  • [ABANDONED] Ozone: Target.WriteU32 bug
    Hi
    I have a strange bug in Ozone (2.56s). I do this:
    Target.WriteU32(0x506000e4,0x90000);
    The console shows:
    Target.WriteU32 (-2147483648, 0x00090000);
    Anyone has an idea what is wrong?
    Addendum:
    Target.WriteU32(0x506000e0,0x90000);
    => Console
    Target.WriteU32 (506000, 0x00090000);
    This is bizar as 0x506000c0 works!
    Same with decimal:
    Target.SetReg("R0",1348468964);
    Target.WriteU32(1348468964,0x90000);
    Target.SetReg ("R0", 0x506000E4);
    The post was edited 1 time, last by 42BS ().
  • It seems the last address byte is somehow "ignoreded":
    Target.WriteU32(0xdc,0x90000);
    Target.WriteU32(0xe0,0x90000);
    Target.WriteU32(0xe4,0x90000);
    Target.WriteU32(0xe8,0x90000);
    Target.WriteU32(0xec,0x90000);
    => Console
    Target.WriteU32 (000000DC, 0x00090000);
    Target.WriteU32 (0, 0x00090000);
    Target.WriteU32 (000000EC, 0x00090000);
    But I just see: It is only a "console" problem. The data is (at least for the above addresses) written to the memory.
    We tried to reproduce it with the 64-bit version on Win 7 but everything was working as expected.
    What OS are you running Ozone on?
    Does this issue happen with only that target device?
    Does it happen only with one specific debug project?
    Could you create a generic project for your target device and see if the behavior changes?
    Quick update. We were able to reproduce the issue when calling the API function in the Ozone Projekt file.
    Under certain circumstances the reported issue could happen. It will be fixed with the next Ozone release.
  • Sorry, I've been on a business-trip.
    Now I simply ignore the log output. My setup script works correctly.
    BTW: Great tool! (Esp. for the price!).
    Another notes or feature requests:
    - Access to environmet variables
    - #include-ing parts of a script
    Could you elaborate on these two points?
    Which environment variables are you referring to and where do you want to access them from?
    What do you mean with #including and what do you mean by "parts" of a script?
