how about emwin WM_PAINT trigger mechanism?
    • how about emwin WM_PAINT trigger mechanism?
      fresh man alway have much question. :)
      A window has been created.
      1. If the text of a text label of the window changed, wether a WM_PAINT message will be sent automatically?
      2. the message "WM_POST_PAINT", is "Send to a window after the last WM_PAINT message is sent",
      for user's code should be code in WM_POST_PAINT or WM_PRE_PAINT instead of WM_PAINT?
      My english is so good. <X
      thanks.
    • case WM_PAINT:
      hMem00_Face = GUI_MEMDEV_Create(141, 15, 76, 76);
      GUI_MEMDEV_Select(hMem00_Face);
      GUI_SetColor(GUI_WHITE);
      GUI_SetPenSize(16);
      GUI_AA_DrawRoundedRect(149, 23, 209, 83, 30);
      GUI_MEMDEV_Select(0);
      break;
      The hMem00_Face is a global var, I count it will be broken 21 times if I set a break point at the "GUI_MEMDEV_Create" line.
      My code is compliled with no Optimzation Level 0.
      The code as it, the result is right. But I use the code below, the result is error, acted as no any effect.
      case WM_PAINT:
      if (WM_HMEM_NULL == hMem00_Face)
      GUI_SetPenSize(16);
      break;
      The hMem00_Face is init as WM_HMEM_NULL.
      So if I use the fisrt codes, is there a memory leak happen? And how I delete the memory device?
      Yes, a window will be marked as invalid on creation and receives as many WM_PAINT messages as neccessary to draw the window. A window can receive multiple WM_PAINT messages, due to clipping. The clipping mechanism will leave out areas which don't have to be drawn (like a opaque window on top of the window to be drawn).
      Take a look this simple application. Each time the background window gets a WM_PAINT message it uses a different color. It will receive 4 messages, one for each area around the child window.
      1. #include "WM.h"
      2. void _cbBk(WM_MESSAGE * pMsg) {
      3. GUI_COLOR aColor[] = { GUI_BLUE, GUI_GREEN, GUI_RED, GUI_CYAN, GUI_MAGENTA, GUI_YELLOW };
      4. static int Index;
      5. switch (pMsg->MsgId) {
      6. case WM_PAINT:
      7. GUI_SetBkColor(aColor[Index++]);
      8. if (Index == GUI_COUNTOF(aColor)) {
      9. Index = 0;
      10. }
      11. GUI_Clear();
      12. break;
      13. default:
      14. WM_DefaultProc(pMsg);
      15. }
      16. }
      17. void _cbWin(WM_MESSAGE * pMsg) {
      18. switch (pMsg->MsgId) {
      19. case WM_PAINT:
      20. GUI_Clear();
      21. GUI_DispStringAt("Hello world!", 10, 10);
      22. break;
      23. default:
      24. WM_DefaultProc(pMsg);
      25. }
      26. }
      27. void MainTask(void) {
      28. WM_HWIN hWin, hWinBk;
      29. GUI_Init();
      30. hWinBk = WM_CreateWindowAsChild(0, 0, 320, 240, WM_HBKWIN, WM_CF_SHOW, _cbBk, 0);
      31. hWin = WM_CreateWindowAsChild(10, 10, 100, 100, hWinBk, WM_CF_SHOW, _cbWin, 0);
      32. while (1) {
      33. GUI_Delay(100);
      34. }
      35. }
      WM_PAINT is the proper position to place you code if you want to draw something in a window. The pre- and post-messages are seldom used and more for preparing a drawing operation.
