[SOLVED] SWO stream to virtual COM port
  • [SOLVED] SWO stream to virtual COM port
    Hi there. I have a PC application which expects to connect to an embedded target's serial port and interpret the stream of serial data received from the target. Now I would like to connect it to an embedded target which is, instead, sending its output via SWO. in other words, I'd like the SWO stream from the target to appear as a virtual COM port on the PC. Do the JLink tools offer an interface through which I can do this? I would be happy to incorporate a JLink DLL and, given an API into the DLL, extract the SWO stream myself and send it to a virtual COM port.
    The following thread should answer your question.
    [SOLVED] Get the SWO debug output thought COM port
  • Thanks, but that seems to be talking about some HW thing called 'VCOM'. What I mean is that I want to take the SWO data stream from the JLink SW and present it internally within the PC as a COM port, so pure software, no additional HW involved. It would be something that incorporated the JLink DLL and created a virtual COM port, a bit like a TAP/TUN interface does for network interfaces.
    Do you publish the interfaces that the Jlink DLL offers to permit this?
    Rob
  • Hi Rob,
    Thank you for clarification. So you are looking for a pure software implementation.
    In that case the J-Link SDK can be used: segger.com/products/debug-prob…nk/technology/j-link-sdk/
    So you can use our J-Link API to request the SWO data that usually e.g. the JLinkSWOViewer would get which you can then process in any other application e.g. in your VCOM application.
