Swap word order on SPI XiP flash
    • Swap word order on SPI XiP flash
      When programming QSPI serial flash, the word order is swapped, and execution fails (core hardfault).
      The device is an NXP Kinetis K8x (K81/K81 family) MCU part, with a Micron or Cypress 128Mb serial QSPI flash part. The MCU has a QSPI peripheral with XiP capability, for which the default configuration is 64-bit Little-endian. When using the external flash as a data device, the 32-bit word order is consistent and correct. However, when using the external flash for executable code, the word order of the instructions is swapped.
      Expected
      ADDR 0004 [byte7][byte6][byte5][byte4]
      ADDR 0000 [byte3][byte2]byte1][byte0]
      Loaded:
      ADDR 0004 [byte3][byte2]byte1][byte0]
      ADDR 0000 [byte7][byte6][byte5][byte4]
      Now, if I set the QSPI peripheral at 32-bit Little endian, the the J-Link programmed code runs. However, data reads now have the each 32-bit word pair swapped.
      Sanity check: I manually swapped the word order of the external function in the Intel Hex file, and then programmed the flash, and everything ran perfectly. (Note that I did not touch the word order of code targeted at the main, internal flash)
      What's going on here? Can the J-Link be set to swap words? Should I be looking at the GNU compiler/linker/objcopy to fix this? Any ideas are welcome.
      J-Link will store data exactly as specified in your binary or hex you are trying to program.
      Is the data also swapped in the binary/hex that gets output by your Toolchain?
      Which target device are you trying to debug exactly?
      Is it on an eval board or custom hardware?
    • Hi Nino,
      It appears that the data is stored exactly as specified in the ihex file, and is not swapped in the toolchain. I appears that the problem occurs with direct memory-mapped reads: pairs of 32-bit words are swapped between reading from flash, and their arrival in the instruction queue. I have tried this on both my custom board (NXP MK81), and an eval board (NXP FRDM-K82F). NXP are investigating: I will let you know what they find.
      Kind regards,
      Denis
    • New
      In the meantime I am trying to find a solution using a JLink Script, triggered from the GDB. The script runs but does not change the register as expected.
      2. *
      3. * InitTarget
      4. */
      5. int HandleBeforeFlashProg(void) {
      6. U32 QSPI_MCR_BASE;
      7. U32 QSPI_MCR_DATA;
      8. U32 QSPI_MCR_64LE;
      9. int r;
      10. Report("J-Link script: NXP_MK8x_QSPI.JLinkScript");
      11. QSPI_MCR_BASE = 0x400DA000; // Address of QuadSPI0_MCR Register on K8x MCU
      12. QSPI_MCR_64LE = 0x0000000C; // 64LE: bits[3:2] = 3
      13. QSPI_MCR_DATA = JLINK_MEM_ReadU32(QSPI_MCR_BASE);
      14. JLINK_SYS_Report1("J-Link script: Reading QSPI->MCR: ", QSPI_MCR_DATA);
      15. QSPI_MCR_DATA = QSPI_MCR_DATA | QSPI_MCR_64LE;
      16. JLINK_SYS_Report1("J-Link script: Writing QSPI->MCR: ", QSPI_MCR_DATA);
      17. r = JLINK_MEM_WriteU32(QSPI_MCR_BASE, QSPI_MCR_DATA);
      18. if (r <0) {
      19. JLINK_SYS_Report("J-Link script: !!Unable to set QuadSPI_MCR to 64bit Little-endian!!");
      20. }
      21. else {
      22. JLINK_SYS_Report("J-Link script: QuadSPI_MCR set to 64bit Little-endian");
      23. }
      24. return r;
      25. }
      output:
      Verify method "Programmed sectors, fastest method" is not supported for this device.
      Changed to "Programmed sectors using read back"
      J-Link script: Reading QSPI->MCR: 0xFFFFFFFF <<< This is not correct - looks like the register read failed
      J-Link script: Writing QSPI->MCR: 0xFFFFFFFF
      J-Link: Flash download: Bank 0 @ 0x00000000
      J-Link: Flash download: Bank 1 @ 0x68000000
