Gui_CopyRect() with ILI9341
    • Gui_CopyRect() with ILI9341
      Hello *,
      I´ve got a Problem on a STM32F407VE with an ILI9341-display. The function Gui_CopyRect seems to be not working.
      A manual copy with:
      for (int x = 80; x < 120; x++)
      for (int y = 80; y < 120; y++)
      GUI_SetColor(GUI_Index2Color(GUI_GetPixelIndex(x, y)));
      GUI_DrawPixel(x+50, y+50);
      is working fine. Any ideas?
      The the Display is connected by the FSMC.
      I'd like to check this, so I got a couple of questions:
      Which color conversion are you using (GUICC_565 or GUICC_M565)?
      What's the width of the interface you are using, 8 or 16 bit?
      Are you using a cache?
      Did you set all read functions properly?
      If you like you can attach your LCDConf.c, GUIConf.h and GUIConf.c. This makes it a lot easier for me and I can take a look into it.
    • Hello Sven,
      Which color conversion are you using (GUICC_565 or GUICC_M565)? - GUICC_M565
      What's the width of the interface you are using, 8 or 16 bit? - 16 bit
      Are you using a cache? - no
      Did you set all read functions properly? - I think so...
      I´m wondering about the fact that while emwin is reading a single pixel (I use the example in the manual with the red cross) for XOR the readmultipledata-function is called with Numitems=3.
