[SOLVED] Multicore Debugging with Ozone ?
  • [SOLVED] Multicore Debugging with Ozone ?
    Hi there,
    since the manual of ozone does not say anything about it, i assume that it is not possible with ozone to be attached to two different cores at the same time. Am i right ? I just want to be sure if this is possible or not. Can i start multiple instances of Ozone ? with different configured projects ?
    In my work with the LPC4370 with 3 MCU it is very helpful to attach to all 3 cores simultaneously with Gdb through different ports on the Gdb-Server.
    If its not possible with Ozone. Is it planned to integrate multicore support in the future ?
    Best,
    Hans
  • Hello Hans,
    Ozone does support multi-core debugging. For each core a new Ozone Instance with a different project must be launched. Attaching also works.
    Any synchronization between the cores for halts etc. is not done automatically and must be taken care of by the user.
