Can't see J-Link XMC with XMC flasher
    • Can't see J-Link XMC with XMC flasher
      Hello everybody!
      I need to ask your support about a trouble I have with my J-Link Lite-XMC4200 product.
      The drivers of the device are reported to be properly installed and working, I see the J-Link on the device management page, both on USB controller and COM.
      But when I try to flash the microcontroller of a PCB via XMC Flasher, the tool can't detect any emulator, I just see an empty window, with no possibility to select any emulator.
      Can you please help me on this trouble?
      I really need to use XMC flasher :)
      Thanks a lot in advance to everybody!!!!
      Max
    • Hello Max,
      Which target device are you trying to connect to?
      Is it on custom hardware or an eval board?
      Can you connect to the target device using J-Link Commander? wiki.segger.com/J-Link_cannot_…ty_using_J-Link_Commander
      What exactly do you mean by XMC Flasher? We are not aware of a software from us called that way.
      Could you provide a screenshot of that situation?
