[SOLVED] Issues flashing PSoC 5LP using SEGGER J-Link
  • [SOLVED] Issues flashing PSoC 5LP using SEGGER J-Link
    I'm having issues flashing a PSoC 5 LP device using J-Link. If I flash the same .hex using PSoC Programmer and Cypress own MiniProg it works.
    If I use PSoC Programmer and MiniProg to read out the memory, I can see that the only difference in the two cases is that when flashing with MiniProg 'Config Flash Area' address 0x0400 contains some data (roughly between 0x0400 and 0x0f80).
    - Anyone knows what this data is?
    - How can I flash it using J-Link?
    - Has anyone else successfully flashed a PSoC 5 LP device using J-Link?
    Thanks, Jacob
  • Hello Jacob,
    Could you provide the hex file in question so we can give it a try on the boards we have here?
    What we know of is that e.g. the PSoC Creator adds some CHECKSUMS to the end of the hex file that are ignored by the Cypress tools but not by J-Flash witch lead to memory being written that did not exist: wiki.segger.com/Flashing_Cypre…t_data_files_with_J-Flash
    So we assume you are running currently into a similar issue.
    Does the information from the Wiki help in your case?
