Antialiasing and trasparency together
    • Antialiasing and trasparency together
      Dear all,
      I'm trying to display an image generated using a memory device with trasparency and antialiasing enabled.
      The image is displayed correctly on a black background, but if I set the background for instance to orange then the antialiased contour of the image is showing black dots.
      1. //[...] Initialisations and so on...
      2. // Create a memory device where to draw
      3. GUI_MEMDEV_Handle hMem = GUI_MEMDEV_CreateEx(0, 0, X_SIZE, Y_SIZE, GUI_MEMDEV_HASTRANS);
      4. // Select memory device
      5. GUI_MEMDEV_Select(hMem);
      6. // Draw something into the memory device
      7. GUI_SetPenShape(GUI_PS_ROUND);
      8. GUI_AA_FillCircle(10 * MAG, 16 * MAG, 3 * MAG);
      9. // Select LCD, display the image and delete the memory device
      10. GUI_MEMDEV_Select(0);
      11. GUI_MEMDEV_WriteAt(m_hMem, point.x, point.y);
      12. GUI_MEMDEV_Delete(hMem);
      What shall I do to make the antialiasing work properly for orange background?
      Roberto
      Please try calling GUI_PreserveTrans(1) after selecting the device and GUI_PreserveTrans(0) before de-selecting the device.
      This should fix the behavior.
      Here is a changed version of your code:
      1. #include "DIALOG.h"
      3. *
      4. * _Test
      5. */
      6. static void _Test(void) {
      7. GUI_MEMDEV_Handle hMem;
      8. //
      9. // Create a memory device where to draw
      10. //
      11. hMem = GUI_MEMDEV_CreateEx(0, 0, 80, 80, GUI_MEMDEV_HASTRANS);
      12. //
      13. // Select memory device
      14. //
      15. GUI_MEMDEV_Select(hMem);
      16. //
      17. // Make sure that the semi transparency gets preserved
      18. //
      19. GUI_PreserveTrans(1);
      20. //
      21. // Make sure the memory device is clean
      22. //
      23. GUI_SetBkColor(GUI_TRANSPARENT);
      24. GUI_Clear();
      25. //
      26. // Draw something into the memory device
      27. //
      28. GUI_SetColor(GUI_ORANGE);
      29. GUI_AA_FillCircle(40, 40, 20);
      30. //
      31. // Make sure to disable GUI_PreserveTrans()
      32. //
      33. GUI_PreserveTrans(0);
      34. //
      35. // Deselct memory device
      36. //
      37. GUI_MEMDEV_Select(0);
      38. //
      39. // Write to LCD and delete the device
      40. //
      41. GUI_MEMDEV_WriteAt(hMem, 10, 10);
      42. GUI_MEMDEV_Delete(hMem);
      43. }
      44. /*********************************************************************
      45. *
      46. * Public code
      47. *
      48. **********************************************************************
      49. */
      50. /*********************************************************************
      51. *
      52. * MainTask
      53. */
      54. void MainTask(void) {
      55. GUI_Init();
      56. GUI_SetBkColor(GUI_LIGHTGRAY);
      57. GUI_Clear();
      58. _Test();
      59. while (1) {
      60. GUI_Delay(100);
      61. }
      62. }
    • Thank you for your help.
      I had to update from 5.28 to 5.32 to use the new function GUI_PreserveTrans().
      If I don't add this block:
      2. // Make sure the memory device is clean
      3. //
      4. GUI_SetBkColor(GUI_TRANSPARENT);
      5. GUI_Clear();
      Than the look of the image is better, but if I add this block then I get a whole black background for the window. It looks like "GUI_TRANSPARENT" is not really transparent, but black...
      I tried to change GUI_USE_ARGB to 1 and 0 but no difference...
      It looks like "GUI_PreserveTrans(1);" is not making any difference, the library update alone is making things better.
      Roberto
      The post was edited 2 times, last by bibi: Adding information ().
      Please post your configuration files?
      - LCDConf.c
      - GUIConf.c
      - GUIConf.h
      If you are using an NXP library you there are no LCDConf.c and GUIConf.c. They use two files named emwin_support.c/.h.
      You shouldn't change this if you are using a precompiled library. This will change the way how emWin handles colors internally.
