[SOLVED] J-Trace defect by over-voltage
  • [SOLVED] J-Trace defect by over-voltage
    Unfortunately, the over-voltage was passed via USB hub to my J-Trace. After opening I recognized that a voltage controller (one of them close to the large JTAG connector) was overheated.
    I would be glad to get the specs/name of the voltage controller(s) in order to be able to repair my valuable device.
    Thanks a lot,
    Marcus
    The post was edited 1 time, last by Marcus ().
  • Hello Marcus,
    What is the S/N of the J-Trace for exact identification?
    Generally we do not recommend repairs on your own as the chance is slim that the replacement of a single part after overvoltage from USB side will fix the problem.
    Alternatively we recommend making use of our trade-in program: segger.com/purchase/trade-in-program/
    From your registration it seems that you still have at least one of the old J-Trace CM non-Pro debug probes. To make your decision easier we have created the following comparison on what improvements you get with the latest J-Trace Pro model: wiki.segger.com/J-Trace_vs._J-Trace_PRO
  • Hello Nino,
    I know, we also have the newer J-Trace PRO which certainly has advantages. Still, the old one was important in my debug configuraiton. It has the following SN/version info:
    J-Trace CM3 V3.2 14-43 SN 203200722
    Kind regards
    Marcus
  • Hello Marcus,
    We have received your request per e-mail as well.
    To keep information at once place this thread will be closed now and further conversation will be via e-mail.
    Please try to stick to one communications channel for future inquires.
