[SOLVED] Program using SDK crashes
  • [SOLVED] Program using SDK crashes
    i'm writing an programm which flash my microcontroller via Segger Flasher/Arm. For this, i use the JLink_SDK in version 632f.
    The programm is written in C#. I wrote some methods for wrapping the API calls.
    If i am calling some of this methods multiple times my program is crashing after calling the API method. I get an result. But than the program crashes with the error code: -1073740940.
    For debugging issues i watched the windows event log.
    The stack shows, that there is an error on netdll.dll (this is a native windows api)
    Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.17134.112, Zeitstempel: 0x6529f37c
    Ausnahmecode: 0xc0000374
    Fehleroffset: 0x00000000000f4d1b
    ID des fehlerhaften Prozesses: 0x3544
    Startzeit der fehlerhaften Anwendung: 0x01d406ffa771f502
    Pfad des fehlerhaften Moduls: C:\WINDOWS\SYSTEM32\ntdll.dll
    Berichtskennung: f235a08c-961e-4a0a-9c61-77caad52f7ab
    Vollständiger Name des fehlerhaften Pakets:
    Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
    Do you know, why this error occured?? Is there something wrong with my api?? Do you have any experience?
    Thanks for replay
    J.Winter
    J-Link SDK support is generally not given through the forum. Please contact us per e-mail.
    segger.com/about-us/contact-us/
