[ABANDONED] Failed to open listener port 2331
  • [ABANDONED] Failed to open listener port 2331
    I'm trying to use the j-LINK EDU debug probe along with a custom board built for our product.
    This board has a STM32L152RE Arm microcontroller and a JTAG pin out to be used with this wire
    I use TrueStudio IDE to build are project.
    It worked well for almost a week, I could flash and debug our board effortlessly from within the IDE itself. Until suddenly it started showing me the following error -
    SEGGER J-Link GDB Server V6.22f Command Line Version
    JLinkARM.dll V6.22f (DLL compiled Jan 12 2018 16:18:01)
    Command line: -port 2331 -s -CPU Cortex-M -device STM32L152RE -endian little -speed 4000 -if swd -vd
    GDBInit file: none
    Terminal I/O port: 2333
    Generate logfile: off
    Verify download: on
    Init regs on start: off
    Silent mode: off
    Single run mode: on
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: STM32L152RE
    Target interface: SWD
    Target interface speed: 4000kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V10 compiled Apr 20 2018 16:47:09
    Hardware: V10.10
    S/N: 260103243
    OEM: SEGGER-EDU
    Feature(s): FlashBP, GDB
    Checking target voltage...
    Target voltage: 1.75 V
    ERROR: Failed to listen at socket (Err = -1)
    ERROR: Failed to open listener port 2331
    Restoring target state and closing J-Link connection...
    Shutting down...
    I can confirm that neither the board nor the Debug probe have an issue because the both of them communicate and establish connection using the 'J-link Commander' (See attached images)
    Please can someone help solve the issue
    According to your post it seems that you are using a J-Link EDU for commercial purposes.
    This would be a violation of the terms of use agreement.
    Do you have another J-Link probe that can be used for commercial purposes (J-Link Base or higher)? Otherwise we would have to close this inquiry down.
