[ABANDONED] SystemView on STM32F779 not connecting with SWD but only JTAG
  • [ABANDONED] SystemView on STM32F779 not connecting with SWD but only JTAG
    I am running a SystemView patched FreeRTOS 10 on the STM32F779-EVAL board using the J-Link Plus and Eclipse to debug. My problem is that SystemView is connecting rather irregularly and cannot be started with SWD interface. Let me try to explain.
    From Eclipse I can debug my code just fine and see the outputs using J-Link RTT Client using SWD as interface. When I start SystemView and press record I get the error:
    "Failed to start recording"
    "Could not connect"
    If I do the same but using JTAG as interface for Eclipse and SystemViewer, it works just fine.
    The odd thing is if I then close the Eclipse debug session, and switch the interface to SWD, SystemViewer now works using SWD.
    It seems like I have to run a JTAG session first before I can run a SWD session. Any ideas what could cause the connection problems using SystemViewer and SWD?
    Setup:
    Windows 7
    Eclipse Mars.2
    FreeRTOS 10
    STM32F779-EVAL
    J-Link v. 6.32d
    SystemView v. 2.52a
    Best Regards,
    Ulrich
  • Hello Ulrich,
    Could you provide us with a J-Link log file of such a session where connect with SWD fails?
