Failed to detect the SPI flash
    • Failed to detect the SPI flash
      Hi everyone,
      I develop a bare metal firmware for the system using iMX6S5.
      It run directly to RAM memory without any problem with debugging through GDB J-Link, JTag and Eclipse.
      However the requirement for the system is booting from SPI Flash. The system use the SPI Flash Spansion S25FL064L.
      I use the J-Flash SPI V6.22f via J-Link to flash the binary but it can not detect the SPI flash.
      The error message is:
      Connecting ...
      - VTarget = 3.317V
      - Read SPI Flash Id = 0x00 00 00
      - ERROR: Failed to auto-detect SPI Flash.
      - Failed to auto-detect SPI Flash.
      I tried to change all the device but have the same result.
      I checked in the document, the SPI Flash Spansion S25FL064L is supported by J-Flash SPI. Can some one here help me to figure it out ? Can I use the J-Flash to flash the binary to SPI Flash ?
      Best Regards,
      Nguyen.
    • Hello Nguyen,
      How is the SPI Flash connected to the J-Link? Direct or indirect?
      More information can be found here: wiki.segger.com/Programming_External_SPI_Flashes
      Currently only direct mode is supported by J-Link for that Flash.
      Indirect mode is not yet implemented. A list with supported iMX6 devices in indirect mode can be found here: wiki.segger.com/IMX_Series_Devices
    • Hi Nino,
      Thanks for your reply.
      My connection is indirect, so follow the link, the JLink SPI can not use.
      However when I use the J-Flash, in the Project Settings/Flash, there is no SPI flash devices as I used. If I choose "Automatically detect flash memory", I have the error:
      - Target interface speed: 12000 kHz (Fixed)
      - VTarget = 3.317V
      - Executing init sequence ...
      - Initialized successfully
      - Target interface speed: 4000 kHz (Fixed)
      - J-Link found 3 JTAG devices. Core ID: 0x4BA00477 (None)
      - Connected successfully
      Blank checking target ...
      - 1 of 1 sectors selected, 1 range, 0x0 - 0xFFFFFFFF
      - Start of determining flash info (Bank 0 @ 0x00000000)
      - ERROR: Could not find CFI compliant flash device
      - Error while determining flash info (Bank 0 @ 0x00000000)
      - End of determining flash info
      - Flash bank info:
      - 1 * 0 bytes @ 0x00000000
      - ERROR: Failed to check blank target
      Disconnecting ...
      - Disconnected
      Programming and verifying target (9176 bytes, 1 range) ...
      - Flash bank info:
      - ERROR: Failed to program and verify target
      Disconnecting ...
      - Disconnected
      Do you have any idea about this issue? Can you suggest me the way that I can flash the binary to SPI Flash?
      Nguyen.
      As I wrote earlier, indirect mode is not yet implemented for the iMX6S5 device series.
      In the Wiki article I linked you you can find a Link to our open flash loader interface: wiki.segger.com/Adding_Support_for_New_Devices
      With the open flash loader you can implement SPI Flash support yourself.
