Hi, I'm trying to use STemWin.
I already found the SeggerEval Software which runs just fine.
I would how ever like to use Software generated by the STM32CubeMX Software.
Normaly that works just fine, I simply create Code choosing the MDK-ARM Toolchain and import the created project to Segger Embedded Studio using "Import Keil MDK project" but when i include the STemWin option I can still import the generated project but can't Build the project. It results in:
Is there an easy way to solve this problem?
unfortunatly the SeggerEval software is based on an older HAL library version, and I tried but cant migrate the STemWin to an existing CubeMX project.
I will continue trying and let you know if when i succed.
best regards
Jannis Dohm
best regards
Jannis Dohm
