When I click the plus button in the build configuration screen to create a new one, it does not allow me to select another configuration to base it off (as it says in the documentation). Additionally, when I create a new one, it is not based on the other configuration in the project. Any idea what I am doing wrong?
[SOLVED] New Build Configuration no longer based on another configuration.
The documentation says:
To create your own configurations, select Build > Build Configurationsto invoke the Configurations dialog. The New buttonwill produce a dialog allowing you to name your configuration. You can now specifythe existing configurations from which your new configuration will inherit values.
So first create a Private config that you want to inherit from and then select it for all Public configs you want to use it with.
NinoPlease read the forum rules before posting.
Or you can contact us via e-mail. -
OK, so the reason I am not seeing the diaglog is that I only have 1 private config (Common)? If so, it would be good to update the documentation so that others will know of this limitation.
We will see if we can improve documentation in that regard.
Share
- Facebook 0
- Twitter 0
- Google Plus 0
- Reddit 0
