[SOLVED] How to download and debug app written in IAR on STR912 so it runs in bank 0 on chip set to boot from bank 1
  • [SOLVED] How to download and debug app written in IAR on STR912 so it runs in bank 0 on chip set to boot from bank 1
    Is it possible to download and debug an app that is expecting to be run in bank 0 on a chip that is set to boot from bank 1? I wonder if I am hoping for the impossible. I think it should be possible but I wonder if it is so weird that the switches aren't available.
    I have managed to download it but it seems that it has put it in bank 1 @ 0 rather than bank 0 @ 0 (looking in the debugger memory over 0x20000 appears as -- which normally implies no flash there. Even after the startup sequence setting the bank sizes, it is still --
    Not surprisingly, if I select the option to verify the download, it is both much slower and fails.
    I have specified the correct device (STR912FAW46) in the control panel incl the boot bank
    Thanks in advance
    We received your request per e-mail as well.
    Please make sure that future inquiries come through one communication channel and not multiple to avoid delays in our response time to your requests.
