Wear-leveling and Journaling file system for NOR flash?
    • Wear-leveling and Journaling file system for NOR flash?
      Is emFile suitable for:
      - nor SQI flash 64Mb
      - use under FreeRTOS (customer requirement)
      Is a hook provided to flush any cache for use entering power-down?
      Or is it expected that external hardware resets the processor while giving the flash time to finish up any operations in progress?
      Thanks!
      Best Regards, Dave
    • Hello Dave,
      emFile supports SPI NOR flash via the NOR driver. The file system can be used with any operating system including FreeRTOS.
      emFile does not provide such a functionality.
      The hardware has to make sure that the NOR device finishes any write operation before power down.
      If the hardware does not comply with this requirement, it is possible to use the CRC verification option
      of the emFile NOR driver to detect and recover from an interrupted NOR write operation.
      The emFile NOR driver is able to recover successfully from an interrupted NOR erase operation.
      Marius
