got the following problem:
Within a Solution is a library project and an executable project (SES3.40 for ARM)
The library is set as a dependency (Common/Code/Build/Project Dependencies) in the executable project.
The library has a pre-build command (for setting SVN-Version in Code) which is set to 'Always Run' (Common/Code/User Build Step/Pre-Build Command...)
The command is called, if the Project is compiled directely, but not if compiled via '(Re)build Solution' or '(Re)build' on the executable Project
Do I miss something or is it a BUG?
Marc
Marc
