[SOLVED] ERROR: Failed to download RAMCode error while flashing STM32L073xZ
  • [SOLVED] ERROR: Failed to download RAMCode error while flashing STM32L073xZ
    I am using Segger JLink Base version with JLink software V6.32D. I am trying to flash board AcSip S76S, its an SOC containing STM32L073RZ (192K flash + 20K RAM) controller with Semtech LoRa modem. I can connect to target, executed few register reads and writes to allow disable read out protection, but I am not able to access internal RAM either through command "Read 32bit" or if I try to enter programming (blank check, erase or flash). I am executing command through JFlash, below are logs when trying to read internal RAM through command "Read 32bit":
    Connecting ...
    - Connecting via USB to J-Link with SN 58006798
    - Target interface speed: 1334 kHz (Fixed)
    - VTarget = 4.995V
    - Executing init sequence ...
    - Executing Reset (0, 0 ms)
    - Executing Write 32bit (0x4002200C, 0x89ABCDEF)
    - Executing Write 32bit (0x4002200C, 0x02030405)
    - Executing Write 32bit (0x40022014, 0xFBEAD9C8)
    - Executing Write 32bit (0x40022014, 0x24252627)
    - Executing Write 32bit (0x40022018, 0x00000F00)
    - Executing Delay (1 ms)
    - Executing Write 32bit (0x1FF80000, 0xFF5500AA)
    - Executing Delay (100 ms)
    - Executing Write 32bit (0x40022004, 0x00040000)
    - Executing Read 32bit (0x20000000)
    - ERROR: Could not read target memory
    - ERROR: Failed to connect.
    Could not perform custom init sequence.
    And below are logs when I try to do blank check:
    - VTarget = 4.917V
    - Initialized successfully
    - J-Link found 1 JTAG device. Core ID: 0x0BC11477 (None)
    - Connected successfully
    Blank checking target ...
    - 1542 of 1542 sectors selected, 2 ranges, 0x8000000 - 0x802FFFF, 0x8080000 - 0x80817FF
    - Start of preparing flash programming
    - ERROR: Failed to download RAMCode.
    - ERROR: Failed to prepare for programming.
    Failed to download RAMCode!
    - End of preparing flash programming
    - ERROR: Failed to check blank target
    Disconnecting ...
    Attaching .JFlash for reference. This is my first time programming SOC based STM32L0 controller. Let me know if I am missing something.
    Harsha
    For the STM32 series devices we offer example JFlash projects for locking and unlocking this devices: wiki.segger.com/STM32
    Your project seems to differ in the init sequence.
    One thing we noticed from your logs is that VTref is nearly 5 V. According to the ST user guide the L07x series has a operating voltage of 1.8-3.6 V.
    If you supply more than that it might destroy the device or lead to unpredictable behaviour.
    Are you certain that voltage is correct? Keep in mind that J-Link will use the voltage level for his signals which he gets as reference from VTref. So J-Link will currently drive the SoC with 5 V as well.
    Thanks for the reply. I created the init sequence taking the example from wiki.segger.com/STM32.
    To this sequence I added additional command to set watchdog to software in FLASH_OPTR register. AcSip module is powered by USB, only SWD lines of JTAG are connected to target board. JTAG pins 1 and 19 are shorted to simulate VTref. Target power supply is set VTGT in Project settings -> Production -> Power source, I will change this to 'NONE' and try again.
    Harsha
  • Hi Nino,
    Thanks for the tip. VTref was indeed the problem, from AcSip module I pulled a 3.3V signal and connected to pin 1 of Jlink and everything went fine (Project settings -> Production -> Power source = VTGT). Please close the thread.
    Harsha
  • Hi Harsha,
